How to set the negative cost amount to 0 ?
I have an Item with no available quantity , yet has a physical and negative cost. as per below
Physical cost amount = -0.20
Financial cost amount = -0.07
Total available = 0
I want to set the Physical and Financial cost to 0. I notice that in transactions , there are options to adjust the ‘Amount’ and ‘Value’. Please advice which option I should use in this case.
I did run the Inventory Recalcualtion. There was a settlement for the said Item but the above costs was not changed.
Is there better way of adjusting the costs to 0 ? let me know . Much appreciated!
Adrian.V
Ensure all invoices are processed then run the inventory recalculation.
