how to set source table in form.
I have a requirement in which i need to connect the server using odbc and then connect my form using a table from the server.
How can i setup the source table for a form at runtime?
Appreciate any help on this regards.
Hi Kami,
Can you describe what the solution you are tring to acheive?
I am trying the assign a DATASOURCE TABLE NAME AT RUNTIME.
To set the SOURCETABLE PROPERTY to the table name.
i.e. FORM.SOURCETABLE = ‘CUSTOMER’;
how to do this how to set the source table name from the code at run time.
Hi Kami,
This is not possible - but you still didn’t explain the overall problem - there may be other solutions e.g. Form.Run( 0, or using a temporary table.
