I am using the SUPER role database login. However, while I try to use Object Designer to modify a form, it shows that “You do not have permission to read the ‘XXXXXX’ Form.”
Would anyone know how to set it?
Hi Koala,
It’s probably down to your license. You will need a development (partner) license to modify standard forms.
Which Form do you want to edit and what sort of licence are you using?
End-user licences need the Form Designer granule.
It may be a Demo version as the following:
Microsoft Software License Information
Copyright (C) 2007 Microsoft Corporation. All rights reserved
License number : W1-ZA-000-A6MZ9-W
Licensed to : CRONUS International Ltd.
John Roberts
5 The Ring
Westminster
W2 8HG London
World Wide 1
0666-666-6666
Granule ID Name Amount Expires
540 Demonstration Basic Granule 1
1,100 Company 2
1,200 Session 2
1,310 Database Expansion per 1 MB 100
1,370 Database Expansion per 1 GB 1
1,520 Server - Windows NT (Intel) 1
1,700 C/ODBC 1
1,800 C/FRONT 1
1,960 Test Integration 1
2,010 Server - Microsoft SQL Server Option 1
2,105 Allow new versions 1
4,900 Application Wide - Multiple System Langua 1
What is the form number you are trying to run ? probably it gives us proper idea to investigate.
