junwey
1
Hello, everyone
I want to set the (PurchReqLine).Name field editable when the (PurchReqTable).RequisitionStatus is ‘InReview’.
I add belows to DataSources.PurchReqLine.active(), but it did not work.
if(purchReqTable.RequisitionStatus == PurchReqRequisitionStatus::InReview)
Item_Name.allowEdit(true);
Thanks in advance
kranthi
2
There is already a code to enable/disable this for edit, look at the setfieldAccess method in the form.
junwey
3
Thanks for your respons, and I found a code to set all of datasource tables disable for edit.
So I will try to create a button to open a new simple form to edit the itemname field.
Best Regards
