I want to set the value of an array item in a contro, for exemple :
test - OnAfterGetRecord()
WHILE ((counter < NbreCmdesMax) DO BEGIN
counter += 1;
controlxxx := Array[counter];
END;
is it possible ? thanks !
counter += 1;
END;
If I had understood correctly. Use ARRAYLEN function.
Could you specify a bit here? Are you trying to set the control to the value of the Array[counter] when counter is a certain number, or do you want to set it to the amoutn of elements that the array holds?
