Did you set your SMTP Server credentials(?) at
Administration–>IT Administration–>General Setup–>SMTP Mail Setup
hi mohana now only i set the SMTP server name,but again i got another error…i think my SMTP server name is wrong.k thanks for your reply…
Hi there,
I’m testing the JMail solution, and it almost works fine.
The problem is, I cannot send emails with more than 1024 characters in the body.
The error message that shows up is something like (translated from portuguese): “The size of the text exceeds the size of internal text memory.”
I think I have tried everything I can remember. I used the AppendText method. I used the AppendBodyFromFile method. None of them work
Am I missing something?
try this http://dynamicsuser.net/blogs/nunomaia/archive/2007/09/10/running-smtp-component-from-nav-5-0.aspx
Well we have used the CU of NAV 5 related to SMTP and imported in NAV 4 SP3 version & copied the required DLL in the NAV folder and registerd them, which are still working fine.
Hi do you have any steps on how to implement jmail with NAV2009r2?
Dear All,
I have a solution for SMTP Server as gmail.stmp.com and it is working Successfully.
reach me at sami.3187@gmail.com
Sami
Please post your suggestions here for me.
google is your friend. Go to Google ask him. It gives you the best solution.
Thanks for that tip! What is thing thing called Google and how do I use it?
Dear All,
I have a solution for SMTP Server as smtp.gmail.com and it is working Successfully.
Sami mohammed
Navision technical Consultant.
Microsoft Certified Professional.
Thanks guys.
