How to run SQL quary using NAV ?
Hi Expert ,
I want to run SQL quary(“select sum(Quantity) as Stock from [CRONUS International Ltd_$Item Ledger Entry] where [Item No_] =‘1968-S’”) using NAV Service/Object. is it possible ? if yes then how it can be possible ?
Surajit
Which version are you using?
Using ADO connection you can run SQL Queries.
http://dynamicsuser.net/blogs/waldo/archive/2008/01/06/using-stored-procedures-in-c-side.aspx
Hi expert,
i am using NAV 2009 R2
Surajit
Did you try above link?
Is it working?
From what environment are you trying to run this statement?
