I ran GL revaluation in AX 2012 and noticed that entries were wrong after revaluation.
Can someone help me on how to reverse these entries?Manual entries won’t be able to correct the initial revaluation entry by currency. Can someone suggest other possible options.
Although I have never this scenario… I believe the best solution would be to change the currency exchange rates back to the previous rate and perform the revaluation again.
I was just going through the hot-fix release file and it mentions of hot-fix “KB 2 9 5 7 2 8 9” in which it is mentioned that it supports the reversal of GL revaluations… It is integrated in CU 6.221000.7184. What is your AX 2012 build? Let me know if you can get your hands on that hot-fix and if it helps your situation.
