How to return more than one column from Lookup ? Need help urgently Regards, Srinivasan V
Hi, on the method lookup (replacement method) of the field you want to have more than one column call a form that have the shape that you want : public void lookup() { FormRun newPopup; Args args = new Args(); ; //super(); args.name(formstr(ThePopupShapeYouWant)); args.caller(element); newPopup = classFactory.formRunClass(args); newPopup.init(); this.performFormLookup(newPopup); } I don’t know if there is another solution but this one is the fastest that I know. It comes from Advanced X++ Course. Regards Thierry
Add all needed field in AutoLookup group of Table.
give it in edt
There are many ways to create a lookup. The answer to your question depends on how you are getting the Lookup.
