how to return a variable declared in fetch method
Hi All, I have used a real variable in fetch method in a report…How to return the value from that variable in a display method in a programmable section…Plz help…
Hi Enrique,
After fetching the value in the real variable in the fetch method. Call the programmable section by element.execute(prog.sec no.), In the programmable section create an display method, and then return this variable there…
Thanks Buddy…That works :slight_smile:
