Is it possible to get the active directory user credebtial details through Ax Code? If yes, how can i do it…plz provided some samples…
I have not done this before but i can give a hint to you. In Axapta X++, u can access the .NET Framework Libraries and for active directory there is one library called as System.DirectoryServices. So, try referencing in your code to access domain services.
I have already used like the below codding says :
static void CreateUserInActiveDirectory(Args _args)
str userName = “NewUser”;
str userPassword = “password”;
str userGUID;
str connection;
System.DirectoryServices.DirectoryEntry directoryEntry;
System.DirectoryServices.DirectoryEntry newUser;
System.DirectoryServices.DirectoryEntries children;
System.Object[] parameters;
parameters = new System.Object1;
try
parameters.Initialize();
parameters.SetValue(userPassword, 0);
connection = “LDAP://dc=Contoso,dc=com”;
directoryEntry = new System.DirectoryServices.DirectoryEntry(connection);
children = directoryEntry.get_Children();
newUser = children.Add(“CN=” + userName, “user”);
newUser.set_Username(userName);
newUser.CommitChanges();
userGUID = newUser.get_Guid();
newUser.Invoke(“SetPassword”, parameters);
directoryEntry.Close();
newUser.Close();
catch (Exception::CLRError)
throw error(“An error occurred.”);
But, there is very simple code to execute even within a job itself…I too done that also before but i lost my xpo’s and i forgot the method which i have done… Now i am wondering how have i done that… So plz help out to find that…
Thanks in Advance
I remember seeing various articles in Internet for reading info from AD. The one I could remember is this - http://dynamics-ax-live.blogspot.com/2010/12/how-to-read-in-active-directory.html
Also if you haven’t done so, would suggest you to search here.
Hello Harish Sir,
Thank you for the link…This is very helpful for me…Thank you very much
I am newbie and not know much about it. But Google is your friend. It gives you the best solution .
I found out the exact link… Thank you for ur good time for me honeyclarck
