how to retrieve a delete_ from table (deleted records)
here is the code
delete_ from xyz
where abc. field1 = xyz.field1;
but I want to retrieve these records some where. please suggest some alternatives.
is triggers availabe on dynammics ax and will that be a good option to solve this problem
if yes how to use a trigger to a table or some place when a delete operation is performed
Thanks all in advance
What does this mean?
The delete method on table will be called, unless you intentionally skip this. You will not be having much impact by using a set based delete which executes the delete method.
So the better option is to perform the what ever operation before set based delete.
http://msdn.microsoft.com/EN-US/library/aa849875.aspx
