How to restrict the result of this function DATE2DMY(date,2) to minimum two digits? Now its giving ‘1’ for January instead of ‘01’. ? I would highly appreciate if you can suggest some workaround to manage this issue.
Not sure whther there is some other way…
you can try
Month := DATE2DMY(010911D,2);
IF STRLEN(FORMAT(Month)) <> 2 THEN
MonthTxt := ‘0’ + FORMAT(Month)
ELSE
MonthTxt := FORMAT(Month);
Message(’%1’,MonthTxt);
If anybody have some other direct solution, please share your experience.
DATE2DMY is a system function, and you cannot change its behavior. That function returns an integer type value. ‘1’ is an integer value, ‘01’ is NOT an integer value but a text value. You will have to create your own wrapper function, take care of conversion, and return a text value that is formatted in the desired manner.
