How to restore particular table in Navision
I am using Navision ver 2.6. I want to inquire about, 1. how to restosre a single or particular tables from the database backup file. 2. Is there a way to restore all the data without index as it takes a lot of time to index all the tables.
Sorry, but it’s a No to both questions. If You wan’t fast restores, I recommend You to upgrade You run-time to 3.60 and use Hotcopy. Hotcompy takes copies of the files, so You don’t neeed to restore the keys as with the normal backup. /Lars
Topic moved from “Break Space” (a forum for fun an entertainment) to “Navision Technical”.
