How to remove unused details from a sales invoice
Hi All
can you tell me how to remove all the uneccesary unused details from appearing when printing a sales invoice, such as “SWIFT COde” and GIRO nr" and “telefax”.
Can I also I add a line at the bottom of the invoice where I can write a comment?
Many thanks
Munim
Hi Munim,
You will need to either change the report layout of the standard report or (prefferably) copy the standard report and modify the layout, then selection the new layout in the report selection form. If you are not familiar with report design then contact your local partner.
