Dear Sir,
When i remove the modification Permission in Table 23, it is not even permitting the user to create the Vendor. which Role i need to add which will permit the user only to create the Vendor and there is no modifications.
Please sugget
LAKSHMAN
select the permission set of that user and add/change a record for Table 23 Vendor:
"TableData | 23 | Vendor | Yes | Yes "
means: read permission, insert permission, no modify, no delete perm.
Sir,
I did the same and sync the ID. it is showing an error you do not have permission to create the vendor
