How to remove Double quotes in .csv file.
Instead of using CommaIO Class use AsciiIo class.
Here is the sample code.
static void removeQuotes(Args _args)
AsciiIo asci;
FileIopermission fileIopermission;
#File
fileIopermission = new FileIoPermission(“K:\Demofloder\Removequotesfile.csv”, #io_Write);;
asci = new AsciiIo (“K:\Demofloder\Removequotesfile.csv”,#io_write);
asci.write(“hi”,“Without”,“Quotes”);
Note: It will work in ax 2009, I don’t know whether it works on later versions are not.
The file will create without quotes.
What’s your question here?
Don’t you confuse this discussion forum with a blogging platform? If so, you can create a blog at blogger.com, for instance.
