How to remove blank Space in Report(MORPHX Report)
Hi Guys,
I set a condition to remove/hide the data if there is no Order Qty and Document Status is Invoice.
but i thought it will be easy, it show’s another problem.
there is a blank space between 2 item, which is the remove/hide data.
i’am using MORPHX Report.
and i don’t how to do it.???
TIA
Help plss…
Anyone?
the data which is hide , can you try using width and height as dynamic.
Hi Kunal,
How can i do that? can you please teach me?
thanks.
Here is the design…
yes you can select the field and check the property , in your case there is some fixed height . remove that and put AUTO
Hi Kunal,
I tried what you’ve said, but still there is a blank space…
Still i can’t get what i want…
i think there is a problem in item description. Previously i faced this kind of issue
Ganesh,
What is the problem in item description?
Really? so how din you solve the problem?
can you share? so that i can try.
tnx.
Jhon,
i have a problem in item description field, its taking its original height and length not depend on description characters.
So, i created a new method for this item description problem is solved.
Ganesh
okay i will try… i get back to :slight_smile:
tnx
Ganesh,
How did you create your method ?
jhon,
Create a display method in the body " Wiz_devPickLis"
display name itemName()
return InventTable::find(datasourceName.ItemID).name;
add this method in the body and drag and drop. It create a string type called" itemName" and put property “dynamicHeight” to Yes.
okay now, how can i return the value to the process report? sorry beginner …
