Now I meet a problem, when I import some data to current record field, but only I leave current rec then back, I can see the value changed. does someone has good method to solve this question?
CurrForm.UPDATE -OR- change the property of the form to YES on UpdateOnActivate
Is this on a Form, a Report, a Dataport? What exactly is “import some data to current record field”?
This behaviour sounds just fine, can you please explain your problem a little better?
Nelson, I think William meant that it is only when he leaves the current rec and goes back, that he can see the new value. Alex’s Dead Lizard’s post seems to solve this. Alastair
Yes, Alastair, I suppose you are right and that was the problem.
