how to recover deleted object in VAR layer in ax 2009?
I have deleted one form from AOT suddenly.I am working in VAR layer,Is there any possibility to recover that form.its a customised form not a standard form.
thanks inadvance
regards,
nivas
I hope there is no option to retrieve it back. But if you have the backup of application, you can get the deleted form from your old application backup.
By replacing the application files in developer env. and export the form which you deleted. Import the form to your deleted AOT.
If it’s deleted, it’s deleted. You need to recovered it from a backup, another environment or so. And if you use version control (and you really should!), you can’t lose anything more than your changes since last checkout.
