I have a customer who has an digital weight interfaced to his pc, using USB.
The way to communicate with this weight is via an HTTP stream. I read the weight from the stream, and I’m able to reset (etc.) the weight by sending simple commands back via the HTTP stream.
I am sure that this is possible to do directly within NAV 2016. I have previously downloaded files directly from HTTP into a file, and expect it to be the same.
The question is really how to send the commands back to the weight using HTTP? Should I be using the same .NET component or is there another to use?
