How to read last 10 records from a table
dear friends
how to read last 10 records from a table in navision . findlast only takes last record …
1.Creata a variable with integer data type for example(RecCount)
2.Reset your table
3.find last record
4.Incraese your RecCount (RecCount:=RecCount+1)
5.then find the previous record by decreasing the the step (rec.next = -1 )
7.if RecCount reaches 10 the stop your itration
Count := 0;
IF Customer.FIND('-') THEN
REPEAT
RecCount := RecCount + 1;
  if RecCount = 11 then
     exit;
UNTIL Customer.NEXT = -1;
Hi Marshal,
don’t you mean FIND(’+’) and NEXT(-1)=0 ?
Hi Thomas
i mean “” rec.Next = -1 “” this ill take you to the immediate previous record from thee current record.
for example a table have 100 rows and you are in the 100th row then if you use “” rec.Next = -1 “” it ill bring you 99th row.
Marshal.J
Dear MARSHAL
sorry to say that its only picking first 10 records
i just tried with a code unit code
RecCount := 0;
IF Customer.FIND(’-’) THEN
REPEAT
MESSAGE ('Customer number : %1 and Name : %2 ',Customer.“No.”,Customer.Name);
IF RecCount = 11 THEN
EXIT;
please give me a correct solution
thanks regards
Akhilesh
hi,
try
IF Customer.FIND(’+’) not ‘-’
Hi Akhilesh
Try this
IF Customer.FindFirst Then
IF Customer.NEXT(Cursor) = 0 Then;
//Cursor is the integer type and Where Cursor = Customer.Count - 10;
Do this its working
Cust.RESET;
IF Cust.FIND(’+’) THEN
BEGIN
REPEAT
Count1:=Count1+1;
MESSAGE ('Customer number : %1 and Name : %2 ',Cust.“No.”,Cust.Name);
IF Count1 = 10 THEN
EXIT;
Cust.NEXT(-1);
UNTIL Count1 = 10;
END;
Dear Akileash here after don’t say “”"" Please GIVE correct SOLUTION “”""" Ok
Jerome Marshal.j
FINDFIRST and FIND(’-’) will work in this case - but it demands command “Customer.ASCENDING(FALSE)” [H]
thanks marshal…
and
thanks to all…its solved my problem…
regards
Akhilesh
