How to read data from .net/webservice dataset.
Hi Community Members,
Have anyone ever study about msdn technical article (Talking with Navision: Accessing Navision Business Layer through a Web Service)? I’ve been trying that article, but I’m getting problem with the c/al code like below:
CC2::MessageReceived(VAR InMessage : Automation “’’.IDISPATCH”)
// load the message into an XML document and find the string node
InMsg := InMessage;
InS := InMsg.GetStream();
XMLDom.load (InS);
XMLNode := XMLDom.selectSingleNode (‘string’);
// parse the request and according to the Request variable, redirect to
// the appropriate function
ParseRequest (XMLNode.text);
CASE Request OF
’GetItem’:
BizLayer.GetItem (Parameters[1], XMLDom);
’InsertItem’:
BizLayer.InsertItem
(Parameters[1], Parameters[2], Parameters[3], Parameters[4],
Parameters[5], Parameters[6], Parameters[7], XMLDom);
ELSE
END;
// open the response queue and create a new message
MQBus.OpenWriteQueue(‘michael\private$\msdnfromnavision’,0,0);
OutMsg := CC2.CreateoutMessage(‘Message queue://michael\private$\msdnfromnavision’);
XMLDom.save (OutMsg.GetStream());
// fill the message and send it
OutMsg.Send(0);
This is the error when I try to compile the codeunit:
When the function is called, the minimum number of parameters should be used…
These are the lines of code that is having problem:
  • BizLayer.GetItem (Parameters[1], XMLDom);
  • BizLayer.InsertItem (Parameters[1], Parameters[2], Parameters[3], Parameters[4],Parameters[5], Parameters[6], Parameters[7], XMLDom);
I am really new in navision and I try to integrate .net and navision using webservice. I want to insert the data from .net using dataset into the navision before it gets to the database.
I hope the Community Members can help me on this problem.
Thank You.
