hey,Guys:
do anyone know how to print 2 vouchers on a paper?
situation: a voucher size is half of A4 paper,i hope that a A4 paper can print 2 report(voucher).
any idea will be appreciate.
Best regards
Bill
hey,Guys:
Best regards
Bill
Hi Bill,
If you design your section(s) to exactly fit half a page, and do all printing in a body-section, then i would assume it happening automatically.
Alexander,thanks for you reply.
but i’m not sure that i exactly understand your meaning:
i need to design all of sections to half of a page? i donnt know how to do that.
do all printing in a body-section?
thank you very much
Hi Billwan,
I ecpext that you already are familiar with the sections-designer.
This is where the actual layout of a report i designed.
If you need to freshen up on it, then find the w1w1adg.pdf in the Doc-folder of the product-CD, and read chapters 12, 13 & 14.
Adjust the height of the sections, to fit a half page.
Body-sections are printed each time a record is handled, whereas header/footer only are generated once per dataitem. (or per group if group-header/footer, or at a pagebreak if trans-header/footer)
So since i guess you want all info printed at every voucher, then you can’t use header/footer-sections.
