Hi, I create an SO for a finished good (manufacturing item) and production starts. I set the ‘pick negative’ on for the production parameters. So production goes through even if no quantity exists in Inventory. However, I don’ want to sales order to packslip if the production item doesn’t exists in Inventory. I set the 'packing slip to “completed” in AR parameters. So, what settings will prevent the user from processing the sales order until the production order is completed?
Is there any parameter settings I should consider, if I select 'ATP" or CTP in the delivery date for the Sales Order?
is there any log somewhere in Production that show who does what - ie. who started the production order, who is completed the stages etc.?
Thanks in advance.
