I can set the VISIBLE and EDITABLE based on a user check, but how do I prevent the LOOKUP for the same users?
For example:
CurrForm.LOOKUPMODE := TeamFilterExists = FALSE;
If the above is correct, where do you put that on the Form or do you have to use the table?
OK I found it, it has to be on every field in the form where a lookup is possible.
Code - OnLookup(VAR Text : Text[1024] : Boolean
