Zen actually posted this onMBSOnline this morning, I just moved it here and send him a message to join us here. It looks like there ar e still many people that have not found us here yet.
Not in Navision I don’t think. You need a key on that field, and since the session table is a virtual one you can’t add it. You could write some functionality that retrieves it from SQL Server using an ADO object, or maybe create a custom table that you populate with all active sessions upon opening the form or something, and then you can slice and dice.
Its not all that hard to sort a virtual table. The easiest is to use a different table to do the sorting wth, in this case, you could for instance use say Item.
So create a Temp Record of Item, create aloop that goes though sessions, and popuates as follows
Item … Session
No. = format(session id)
Search Name = User Name
commission group = session id.
item.insert etc…
at the same time populate a temp rec of sessions.
then just create a new sessions form that opens with item rec as source, and sort by search name. then
on next rec etc just do a
Tempsession.get(tempitem.commision group);
etc.
Now I wouldnever recommend this for normal business use, but since its just an it tool, and not business critical it shoudl be fine.
Of course don’t go and delte all your items by accident, that would not be nice.
I think there is a key for UserID on the sessions database, at least you can go File >> Database >> Information >> Current Sessions and then sort by userID.
I see the key! Wow, all this time I did not know it was there and never bothered to check. A lot of other keys to sort on as well that seem ultra useful, including the Blocking fields. But, only on the SQL version it seems. Awesome. Thanks for the tip!
SOrry, I only brought over a part of the thread, so you couldn’t have known that Zen is on 3.70 C/SIDE, my answer was based on already knowing that. [:$]
PS another reason to update your profiles people !
Yes I see it now too. Cool you learn something new every day, thanks for the tip. I have all my databases on SQL Server, so I’d have to check out C/SIDE.
