Hello All,
Basically I’m not well-versed with AX but have been working on AX for past couple of months as a developer.
I’m implementing a help desk module in AX and need inputs for the following points.
If I configure the additional user group in AX how can I deploy it on a different server (Testing Server?)
The same as mentioned above how I can deploy the setting made for menu (additional menu added to the existing modules) on Testing Server.
Is there any one simple way to do the above 2 points in one go like import and export all my day work and deploy it on testing server.
Thank You.
