I’ve created Pickinglist journal using Prod id, itemid, bom unit, bom consump, inventory dimensions
I’ve some doubts …
Is it necessary to give proposal value?
How could I post my journal through x++?
Thanks in advance
I’ve some doubts …
Thanks in advance
No
Use \Classes\ProdJournalCheckPostBOM
When I try to post using code I’m getting error as
But i when post manually it’s getting posted…
My form is
My coding is
while select forupdate pjttmp where pjttmp.TransactionStatus == ProdJournalTableTempStatus::Post
try
ttsbegin;
prodJournalCheckPostbom= ProdJournalCheckPostBOM::newPostJournal(pjttmp.JournalId,true);
prodJournalCheckPostbom.run();
pjttmp.TransactionStatus =ProdJournalTableTempStatus::Posted;
pjttmp.PostedDateTime = datetimeutil::utcNow();
pjttmp.(fieldnum(ProdJournalTableTemp,ModifiedBy))=pjttmp.createdBy;
pjttmp.(fieldnum(ProdJournalTableTemp,ModifiedDateTime))=DateTimeUtil::utcNow();
pjttmp.update();
pjttmp.update();
ttscommit;
info(strfmt("Posted"));
catch(Exception::Error)
continue;
How is the journal created when posted manually and using code?
Also check, if the \Data Dictionary\Tables\ProdJournalBOM\Fields\InventConsump is updated properly.
No, Kranthi.
InventConsump isn’t filled Kranthi for that prodid…
How can we fill that?
I created the journal by passing necessary field values from temp table to prodjournalbom table
It is equivalent to BomConsump in inventory unit. Convert BomConsump to quantity in inventory unit and assign that value to InventConsump.
For reference see, \Classes\ProdJournalFormTransBOM\fieldModifiedBomUnitIdPost
like that is it any class for InventProposal field value, kranthi?
You can assign InventConsump value to InventProposal and BomConsump value to BomProposal
Example:
prodJournalBOM.BomProposal= prodJournalBOM.BomConsump;
prodJournalBOM.InventProposal = prodJournalBOM.InventConsump;
Is it necessary to update BOM qty and QtyBOMCalc fields in ProdBom table for pickinglist journals?
Not necessary. The insert() on prodJournalBOM will handle it.
But when i check the values in prodbom table for my journal id those fields are empty, kranthi
How was the ProdBOM created? Try creating a new production order and check.
Do you still get the error after updating the InventConsump ?
