Need to know how to place a report in Shortcuts. The report is a custom report (actually, just a customer statement modified) located in the 50000 range.
I want to use this report as a default but I cannot find the Report Selection for Customer Statement. Went to Administration, Application Setup, Sales & Marketing, Report Selections. The Usage drop down box lists everything but Customer Statement.
After we upgraded from 2.0 to 4.0 I couldn’t find a lot of reports, what used to be in sales and receivable reports, was now in financial management → cash management → reports, so I made a menu just for reports, now all reports our company uses can easily be found on one menu. If someone finds they need something that is not on that menu it is easy to add it. And all the custom reports, like your statement can be found easily also. Then the users can add to there own shortcuts the reports they use most often.
1/ the actual one - how to add a reprot to a short cut whichis expalined by Phenomenen
2/ Reading between the lines it seems like you want this to be the standard report for customer statement. In this case I don’t think there is a standard report for Customer statement. The deault Slaes docuemnt setup is used so that speciic reports can be used during processing, such as Post and Print. But thre is no where that you would call a custmer statement in this way. Maybe you had a mod in your old ssytem, and it was not brought accross.
I tested my login (Superuser) and the correct modified customer statement form printed that is located in the 50000 range. Next I login’d in as the user in question and ran the same routine. The user defaults to the 10000 range document. This is the incorrect form.
I may have stated “report” but I meant “document”. The document is what needs to be used as the default.
The form is found in Financial Management, Receivables, Documents, Customer Statements.
In the Navigation Pane, we have new catagories to reduce the amount of areas to lessen confusion and secure areas. I was looking at an old (default) catagory, placing the correct report in the old catagory and compiling. When I restarted the program login’g on as a different user (the one who needed the different report selection), the old catagories do not appear for the user. Therefore, I was going crazy trying to figure out why Dynamics NAV was broke. Once I discovered the default catagory held the report, I inserted the report in the new catagory and bingo, it appeared!
