I have problem in passing record args from main method to Run method.
I will share my code here so you can understand what i am trying to achieve.
class WIZDRRepDialog extends RunBase
DialogFIeld repIdField, repReasonField;
DRRepParameters dRRepParameters;
DRRepNumSeq dRRepNumSeq;
protected Object dialog()
DialogRunBase dialog;
FormStringControl ctrl1;
dialog = super();
repIdField = dialog.addField(ExtendedTypeStr(DRRepNumSeq), "Select Reason: ");
ctrl1 = repIdField.control();
ctrl1.registerOverrideMethod(methodStr(FormStringControl, lookup), methodStr(WIZDRRepDialog, lookupTest), this);
return dialog;
public boolean getFromDialog()
// Retrieve values from Dialog
dRRepNumSeq = repIdField.value();
return super();
protected void lookupTest (FormStringControl _control)
Query query = new Query();
QueryBuildDataSource queryBuildDataSource;
SysTableLookup sysTableLookup = SysTableLookup::newParameters(tableNum(DRRepParameters), _control);
sysTableLookup.addLookupField(fieldNum(DRRepParameters, Key));
sysTableLookup.addLookupField(fieldNum(DRRepParameters, Reasons));
queryBuildDataSource = query.addDataSource(tableNum(DRRepParameters));
sysTableLookup.parmQuery(query);
sysTableLookup.parmTmpBuffer(DRRepParameters); //set our populated buffer!
sysTableLookup.performFormLookup();
public static void main(Args _args)
WIZDRRepDialog repCreate = new WIZDRRepDialog();
// Prompt the dialog, if user clicks in OK it returns true
if (repCreate.prompt())
repCreate.run();
public void run()
Args _args = new Args();
str strMessage = "PAULIT-ULIT!? KAYA KA NASASAKTAN EH! \nYour Trial is Excedeed! \nPlease coordinate with CNC Department.";
str strTitle = "DR Request Reprint Form";
Notes notes;
WIZDRRepDialog controller = new WIZDRRepDialog();
CustInvoiceJour custInvoiceJour;
wizRequestTable requestTable;
dRRepParameters = DRRepParameters::find(dRRepNumSeq);
if (dRRepParameters)
if(_args.dataset() == tableNum(CustInvoiceJour))
custInvoiceJour = _args.record();
if (wizRequestTable::find(custInvoiceJour.RecId, custInvoiceJour.dataAreaId).ApprovalStatus != DRApproval_Status::ForApproval
|| wizRequestTable::find(custInvoiceJour.RecId, custInvoiceJour.dataAreaId).ApprovalStatus == DRApproval_Status::None)
if (custInvoiceJour.CountPrint != 2)
requestTable.Reason = dRRepParameters.Reasons;
requestTable.RepId = dRRepParameters.Key;
requestTable.InvoiceId = custInvoiceJour.InvoiceId;
requestTable.SalesId = custInvoiceJour.SalesId;
requestTable.CustInvoiceJourId = custInvoiceJour.RecId;
requestTable.ApprovalStatus = DRApproval_Status::ForApproval;
ttsBegin;
requestTable.insert();
//salesTable.update();
ttsCommit;
Box::info("Sucessfully sent!", "Request DR Reprinting");
else
Box::warning(notes, strTitle, '');
else
Box::warning(strFmt('Invoice Id %1 is still pending for approval', custInvoiceJour.InvoiceId),strTitle,'');
else
error('Reprint Id is not found!');
else
throw error("Incorrect table record for processing");
super();
If you have better ideas or suggest, please let me know.
Thank you in advance.
