how to pass Parameter from Page List to Menu Item
I have a SSRS Report, Produce Report Base on SalesID in SalesTable. I embedded the Report behind the menu item in the ribbon of “All Sales Order”. i want to choose one of the sales order and click on menu item to print the report for me. So, how can I pass The SalesID parameter to Print Menu Item?
any help would be welcomed!
Which version of AX? If AX 2012, do you have sales ID as a separate parameter or is your goal to add a range to a query?
It’s AX 2012 R2. No I don’t want it as a range. I want pass it as a separate parameter from sales table pagelist to the menu item. TanQ for your respond
Hi Monir,
Do do this U need to create a new class extend it srsReportRunController class and override the prePromptModifyContract method Like
protected void prePromptModifyContract()
Query query;
QueryBuildDataSource qbds;
Salestable salesTable;
salesTable= args ? args.record() as salesTable: null;
if (salesTable.RecId)
//get the query associated with the report
query = this.getFirstQuery();
qbds = query.dataSourceTable(tableNum(Salestable ));
qbds.addRange(fieldNum(salestable ,salesID)).value(salestable .SalesID);
create New main method in the class and call the report from there like
public static Void main(_args)
Myclass mc = new Myclass();
mc.ParmReportname(srsReportstr(reportname,reportdesignname));
mc.Parmargs(_args);
mc.startOperation();
assign this class in a action menuItem to the form and assign datasource property as SalesTable …
Great, it’s work.
TanQ vinothkumar
