How to pass null value in Multi-select value
Hi Guys,
Need some help here, because i need to create a report w/ parameter that can handle multi-select value…
i follow this instruction >>> Multi select lookups.
After creating the classes, i proceed in creating SSRS report in the properties of parameter the Multi value is automatically “TRUE”, now to accept a null value i need to change the Allow blank and Nullable to TRUE, but there is a error
“cannot accept null value”
Why i need to blank the parameter? because sometimes i don’t want to use the parameter such as:
BRAND
CATEGORY
SUB CATEGORY
how to avoid this error? or is any ways to solve this issue?
thank you.
HI JEMT,
Have you changed parameter properties in VS.
Path
VS–>Parameters node–>Particular parameter–>Properties
Allow blank = True
Nullable = true
Try this.
Suresh.G
Hi Sir,
I do that, i already said that above…
tnx
