hi all,
i am trying to develop a ax 2012
Functionality
the scenario i is : when user select a mutliple line in a grid and click on > function > create purchase order menubutton
it should transverse record which contains tthe salesid -salesline
in standard it is allowing for one record , when i am trying to do not able to pass the container value to init method of the form
the problem here is : i have written code in clicked method and it is working fine
after that ,it hits the class purchcreatesaleorderform class in this a main and mainonserver methods are there
i am getting the value in main class -conttainer values but after this main on server method calls
from this i am not able to pass my container value to form :init method ;
code as follows :in main method
switch(callerFormName)
case formStr(ProjSalesItemReq):
pcgarg =args.parmObject();
callerrecordloc =args.record();
consaleorderlist = pcgarg.parmcontainer();
PurchCreateFromSalesOrder.parmcontainer(consaleorderlist);
for(counter =1; counter<=conLen(consaleorderlist) ; counter++)
salesidloc =conPeek(consaleorderlist,counter);
select SalesTable
where SalesTable.SalesId ==salesidloc;
callerrecordloc = SalesTable;
qbds = q.addDataSource(tableNum(SalesLine));
qbr=qbds.addRange(fieldNum(SalesLine,SalesId));
qbr.value(salesidloc);
PurchCreateFromSalesOrder::pcgmainOnServer(callerrecordloc,args.parmEnum(),consaleorderlist);
after this pcgmainOnServer method not able to pass my container value ,if i passed here with parameter container
from here not able to get the value in the form init method …
if any body know the solutions please help me …
