When open Transaction detailed form (ex: PurchTable, SalesTable,etc), by default the form is opens in “Line view”. How/where to set this option to open the detailed form in “Header view”.
Thanks in advance,
Thanks in advance,
hi,
put this below code in run method in form after super();
element.task(1320);
regards,
Jacek
Thanks Jacek, it is working.
Can i know, what is the 1320 referring here. How can we determine this number?
Thanks in advance,
It’s a command ID.
Open SalesTable form (for example) in AOT and navigate to Design > ActionPabeHeader > SalesOrder > ShowGroup. You’ll find two command buttons there, HeaderViewButton and LineViewButton.
Open properties of HeaderViewButton and place the cursor to the value of its Command property. You’ll see “Header view: 1320” (i.e. command name and ID).
