How to open ax in different remote environment from C# Code ?
I am trying to open an Ax instance using C# in a different RDP Environment(Remote Desktop) to read labels from AOT using Logon(Company,Language,Object Server,Configuration) ,but to no success till now.
Does anybody know how to go about this problem ?
The code is given below.
class Program
STAThread]
static void Main(string[] args)
Axaptaax;
stringAxConfig;
string sID = “@SYS21669”;
objecto;
boolb;
AxConfig =
@“TST2_USR”;
try
// Login to Microsoft Dynamics Ax.
ax =
new Axapta();
ax.Logon(“xyz”, “en-us”,“V1-SDAX-02”,AxConfig);
catch (Exception e)
Console.WriteLine(“An error occurred in object creation or Axapta logon: {0}”, e.Message);
return;
// Logon was successful.
try
// Call a static class method.
// In this example, call SysLabel::labelId2String2
// to determine the label string for a particular label ID.
o = ax.CallStaticClassMethod(
“SysLabel”, “labelId2String2” , sID);
catch (Exceptione)
Console.WriteLine(“An error has been encountered during CallStaticClassMethod: {0}”,e.Message);
b = ax.Logoff();
return;
// Display the returned string.
Console.WriteLine(“The label string for {0} is {1}.”, sID, o.ToString());
Console.WriteLine(“Press any key to continue.”);
Console.ReadLine();
// Log off from Microsoft Dynamics AX.
b = ax.Logoff();
What’s the problem? Do you get any error? Does it work with the default configuration (all parameters set to null)? What’s your version of AX?
