How to modify a record "CreateDateTime"?
Hello,
I have a table that has existing record. Now I turn on the property “CreateDateTime” to Yes.
All existing records is having the same “CreateDateTime” as today.
How can I modify the existing record “CreateDateTime” field?
Thanks in adavance.
Make a processing report on table and modify the records for “CreateDateTime” field.
regards\ vimal
Hello,
You need to use ‘overWriteSystemFields’ method to update system fields. Have a look under Classes\ReleaseUpdateDB41_Basic\updateBatch for inspiration.
hi,
how the sytem knows the createddatetime of the previous records???
regards
Kranthi
Hello,
I try to use the OverWriteSystemFields method, but when I run the job, it prompt error as
Request for the permission of type ‘OverwriteSystemfieldsPermission’ failed.
(S)\Classes\OverwriteSystemfieldsPermission\demand
(S)\Classes\xRecord\overwriteSystemfields
My job is:
permissionSet.add(new SkipAOSValidationPermission());
permissionSet.add(new OverwriteSystemfieldsPermission());
CodeAccessPermission::assertMultiple(permissionSet);
ttsbegin;
inventJournalTable = inventJournalTable::find(“02”, true);
inventJournalTable.overwriteSystemfields(true);
inventJournalTable.(FieldNum(InventJournalTable, CreatedDateTime)) = inventJournalTable.PostedDateTime;
inventJournalTable.doUpdate();
inventJournalTable.overwriteSystemfields(false);
CodeAccessPermission::revertAssert();
ttscommit;
Do you know the reason for fail?
Try to update the createddatetime field directly from database…
Regards
kranthi
Hello Kranthi,
Yes, finally I give up X++. [:S]
I did the update in SQL.
