how to merge the 2 rows on 2 cells in RDLC Report(Navision 2013)?Please tell me the solution.
Thanks & Regards,
Baba Guru.
Thanks & Regards,
Baba Guru.
Are you sure it is rown and not columns?
if yes, it is not possible to Merge the rows.
You need to add a rectangle first and then text bozes on top of the rectangle
Thanks for reply…How to place a rectangle between 2 cells?Is it possible?
You need to merge 2 columns first and then place a rectangle
