how to make the dynamically added fields in the grid as read only?
I have the requirement that to give the ability to user to add any fields dynamically from front end.It is achieved by default in ax.But now they want that field should be read only.How I have to do that?Can any one help me?it is urgent.
Do you mean the Personalization?
technet.microsoft.com/…/aa597239.aspx
Hi Kranthi,
Sorry for the delay.Yes What you are asking is correct.And I went through the link which is given above and that is very nice.But If I have more than 20 fields means what i have to do.whether I have to change for each and every fields(functionally)?
You can add only one field at a time and change its properties.
Hi Kranthi,
Thanks for the response.Is there any other option for this, because the user wants that whenever they add the fields, they want that field as non-editable automatically(This is for that particular form).
