How to make printer ZM400 Zebra print the same length for all lables?
Hi everybody,
I use printer zebra ZM400 to print bar code labels.
Printer ZM400 doesn’t print the same length for all labels.
For example, when I set label length is: 330 mm & set up custom commands in Printing Preferences like:
^XA
^FO^LL7516.2624236
^FS
^XZ
When I print 3 copies at the same time. The first copy is printed with length 330 mm.
The second copy is printed with length 310.7mm
And the third copy is printed with length 305 mm or about that.
I set in control panel of Printer with this configuration:
View Printer Configuration
  JAY188647.1006121.79400-011.N.JABIL.
  +10                 DARKNESS
  2 IPS               PRINT SPEED
  +000                TEAR OFF
  TEAR OFF            PRINT MODE
  CONTINUOUS          MEDIA TYPE
  TRANSMISSIVE        SENSOR SELECT
  DIRECT-THERMAL      PRINT METHOD
  2433                PRINT WIDTH
  7516                LABEL LENGTH
  39.0IN   988MM      MAXIMUM LENGTH
  MAINT. OFF          EARLY WARNING
  NOT CONNECTED       USB COMM.
  BIDIRECTIONAL       PARALLEL COMM.
  RS232               SERIAL COMM.
  9600                BAUD
  8 BITS              DATA BITS
  NONE                PARITY
  XON/XOFF            HOST HANDSHAKE
  NONE                PROTOCOL
  000                 NETWORK ID
  NORMAL MODE         COMMUNICATIONS
  <~>  7EH            CONTROL PREFIX
  <^>  5EH            FORMAT PREFIX
  <,>  2CH            DELIMITER CHAR
  ZPL II              ZPL MODE
  CALIBRATION         MEDIA POWER UP
  CALIBRATION         HEAD CLOSE
  OFF                 BACKFEED
  +000                LABEL TOP
  +0000               LEFT POSITION
  DISABLED            REPRINT MODE
  070                 WEB S.
  070                 MEDIA S.
  060                 RIBBON S.
  044                 TAKE LABEL
  050                 MARK S.
  002                 TRANS GAIN
  032                 TRANS BASE
  087                 TRANS BRIGHT
  213                 RIBBON GAIN
  012                 MARK GAIN
  DPSWFXM             MODES ENABLED
  .......             MODES DISABLED
  2496 24/MM FULL     RESOLUTION
  V53.17.7Z <-        FIRMWARE
  1.3                 XML SCHEMA
  V37 --------- 38 2  HARDWARE ID
  CUSTOMIZED          CONFIGURATION
  10944k...........R: RAM
  2048k............E: ONBOARD FLASH
  NONE                FORMAT CONVERT
  FW VERSION          IDLE DISPLAY
  11/18/10            RTC DATE
  15:29               RTC TIME
  DISABLED            ZBI
  2.1                 ZBI VERSION
  4,116 IN            NONRESET CNTR
  4,116 IN            RESET CNTR1
  4,116 IN            RESET CNTR2
  10,457 CM           NONRESET CNTR
  10,457 CM           RESET CNTR1
  10,457 CM           RESET CNTR2
  SELECTED ITEMS      PASSWORD LEVEL
With that configuration, backfeed is set up: OFF
Could you please tell me how to fix it? I want all labels are printed with the same length 330mm.
Appreciate with your valuable help :slight_smile:
Phuong Tran.
Maybe it a solution: http://www.fixya.com/support/t458781-zebra_105sl_printer_not_print_correct
I need to check :slight_smile:
No, It’s still not a solution :frowning:
Anyone help me pls, thanks!
