Hi everybody,
I use printer zebra ZM400 to print bar code labels.
Printer ZM400 doesn’t print the same length for all labels.
For example, when I set label length is: 330 mm & set up custom commands in Printing Preferences like:
^XA
^FO^LL7516.2624236
^FS
^XZ
When I print 3 copies at the same time. The first copy is printed with length 330 mm.
The second copy is printed with length 310.7mm
And the third copy is printed with length 305 mm or about that.
I set in control panel of Printer with this configuration:
View Printer Configuration
JAY188647.1006121.79400-011.N.JABIL.
+10 DARKNESS
2 IPS PRINT SPEED
+000 TEAR OFF
TEAR OFF PRINT MODE
CONTINUOUS MEDIA TYPE
TRANSMISSIVE SENSOR SELECT
DIRECT-THERMAL PRINT METHOD
2433 PRINT WIDTH
7516 LABEL LENGTH
39.0IN 988MM MAXIMUM LENGTH
MAINT. OFF EARLY WARNING
NOT CONNECTED USB COMM.
BIDIRECTIONAL PARALLEL COMM.
RS232 SERIAL COMM.
9600 BAUD
8 BITS DATA BITS
NONE PARITY
XON/XOFF HOST HANDSHAKE
NONE PROTOCOL
000 NETWORK ID
NORMAL MODE COMMUNICATIONS
<~> 7EH CONTROL PREFIX
<^> 5EH FORMAT PREFIX
<,> 2CH DELIMITER CHAR
ZPL II ZPL MODE
CALIBRATION MEDIA POWER UP
CALIBRATION HEAD CLOSE
OFF BACKFEED
+000 LABEL TOP
+0000 LEFT POSITION
DISABLED REPRINT MODE
070 WEB S.
070 MEDIA S.
060 RIBBON S.
044 TAKE LABEL
050 MARK S.
002 TRANS GAIN
032 TRANS BASE
087 TRANS BRIGHT
213 RIBBON GAIN
012 MARK GAIN
DPSWFXM MODES ENABLED
....... MODES DISABLED
2496 24/MM FULL RESOLUTION
V53.17.7Z <- FIRMWARE
1.3 XML SCHEMA
V37 --------- 38 2 HARDWARE ID
CUSTOMIZED CONFIGURATION
10944k...........R: RAM
2048k............E: ONBOARD FLASH
NONE FORMAT CONVERT
FW VERSION IDLE DISPLAY
11/18/10 RTC DATE
15:29 RTC TIME
DISABLED ZBI
2.1 ZBI VERSION
4,116 IN NONRESET CNTR
4,116 IN RESET CNTR1
4,116 IN RESET CNTR2
10,457 CM NONRESET CNTR
10,457 CM RESET CNTR1
10,457 CM RESET CNTR2
SELECTED ITEMS PASSWORD LEVEL
With that configuration, backfeed is set up: OFF
Could you please tell me how to fix it? I want all labels are printed with the same length 330mm.
Appreciate with your valuable help
Phuong Tran.
