I know we can create new item manually without template and assign all information needed, but I’m in a situation where item template seems to be more helpful for my case. The problem is, list of item template which is provided in a pop up window when we create new item doesn’t meet my need. I need to add my item template to those pop up item window template. Anyone know how to do this? By the way I’m using Ax 2009.
In my inventory, I have a Item group. But I want to have one item sub group also so that my reporting will be more meaning. But in inventory module i do not find any additional field to accommodate this sub group. How to solve this problem
what i am trying to say is , assume that user created the 2 templates and user enabled the option Don’t ask me again . Now how can userenable the same templates again with creating the new one ?
( you are suggesting to create the new template , user does not want to create new template)
The response is still valid, create a new template which forces the system to ignore the “Do not ask again” and you are presented with the dialog box - just create one and then creatre a new item, reset it and then delete teh unwanted template.
I guess there is no other way by which we can enable the “Do not ask again” checkbox. So lally this is the only way, and as adam said you can delete the unwanted template from the prompt by pressing alt+f9.
