how to make invisible field in rdp ssrs report
how to make invisible some field in ax 2012 ssrs report.actually i have customived purchase order confirmation report .for same purchse order confirmation i want return order when qty & amount is negative.so in return order confirmation report i want to invisible some field but it should be visible in purchase order confirmation report
please suggest me
hari
In SSRS … right click in the colum or row then visibility … change the option to: “show or hide based on an expression” and there you modify the expression. Good luck
