Can anyone explain how to make Full CIL compilation in ax 2012 ?
Thanks in Advance
Thanks in Advance
Open AOT (CTRL+D) and then right click on it to get Full CIL compilation option… It is also available on System administration module under Setup.
Its gave an error message as CIL generation: The given key was not present in the dictionary.
This error happens when you got do full compilation for a long time… Please do a full compilation open AOT under the developer mode and there will be option in tool bar build under build u will get full compilation and when you click on that it will ask you to proceed as it may take 5-6 hrs click yes
