I want to make a copy of an object in the database to make modifications to it, but I can’t figure out how to copy an object (report, form…) to a new ID so I can work with the copy while leaving the original intact.
Simply design the object and then click on “File|SAVE AS” and then save as a new object ID and a new Object Name. [:O)]
Thanx! I knew there had to be a simple way…
Or - while in desigmode - simply change the ID and Name of the object in the objectproperties [^]
In the Object Designer: Use Copy and Paste, then change the ID and the name of the new Line. br Josef Metz
