I need to change the On hold Vendor hold status that status should br updated on Vendor hold
Note: i want to change the status “System Administrator” role only
Suggest me any one Please
You can create a boolean field on user setup table and then assign the permission to administrator only and put a code on the vendor table vendor hold field to check against the user setup table field.
