How to Lock the grid filter for Reference Field
Hi everyone,
Version : Ax2012 R2
Problem: I want to disable the Grid Filter for the Reference Group Field using the form Grid. How can I achieve this.
CTRL+G will allow to use the grid Filter, I want to Lock the filter range of Reference Group field which is used in the grid.
In AX 2009, i used the following code on formdatasource ExecuteQuery() method :
this.query().dataSourceNo(1).Addrange(Fieldnum(YourTable,YourField)).value(yourRange);
this.query().dataSourceNo(1).addRange(fieldnum(YourTable,yourField)).status(rangestatus::Locked);
it locks the range on the value YourRange
this should work in AX 2012
Hope it helps
Thomas
Thanks for the response.
It will work only for Normal field , not for Reference Group Fields, I have already tried this solution but it is not working.
