Lets say that iam working in a certain card in Navision (classic client), when I press CTRL+ F2 I come to the design form. I want to see to which table the selected field belong too?
usually I look at source expression , but in case there was more than one Glabal varibales I have to searcg in all records to find the tabel which are connected with the field. I just want an easy way to know the Tabel name for a select field ?
You have already posted same question here and got answer
http://dynamicsuser.net/forums/t/76330.aspx
I tried with zoom function but its not working as I was told
I have a nother way which is looking through the global valus! but this way take too much time, Iam sure there is a nother way or another Keyboard short cut then when a user press he can know the name of the tabel which are connected to the field.
sorry but I thought the answer that I got before work ffor all cases, but itnot. there must be abnother way.
Thanks a lot
Zayed
One of the drawbacks of the Zoom feature as implemented in RTC is that it doesn’t work at all on subforms. If you’re looking for source table references for subform controls, your only option is to track them down through Object Designer. Or, you can add code to your pages that includes a control that has TABLECAPTION as a source expression. Or you can add an Action control that displays the same value. This will at least show you the name of the table that the page is based on. The caveat there though would be that not all controls on a page have a table field as a source, some are based on global or local variables defined in the page object.
Not quite correct. If you are in a subform (e.g. Sales Line), try press Ctrl+Alt+F1.
Bravo Anfinnur, I wasn’t aware of that feature. Everything I had read so far had said that it wasn’t supported. Happy to see that that’s not the case. Thanks,
