I work for a company where most of reports have been take out in excel sheets, because of this the Excel Buffer table remains locked most of time and the end users get error message “The another user has been locked the table wait until…”. If you have any solution to prevent this problem then suggest me.
we use excel buffer to temporarily store report data while report is still in process. the reason we get this issue of locking is when we initialize excel buffer at pre-report and enter the report filters into it and then wait for report to process to enter the report output into it. i believe here the excel table is kept locked for other…can u confirm this is how Nav works
In C/AL code, the Excel Buffer table is used in a variable. This variable should be set as a temporary variable (open locals/globals, look at properties and set the ‘Temporary’ property to ‘Yes’). Because that way the data is not actually stored in the database, because it lives in the session’s memory, you will never have locking issues.
