Does any one know how to integrate Fixed asset in module project management and accounting ?
my project type is Investment. I have set it, but when i go to the FA number and the FA’s value is not acquired.
I have follow the step in module project for advance manual
Do i miss some set up ?
Thanks in advance
Regards
Rudy
Hi Rudy,
Are you looking for updating the FA(acquisition) from the investment project? Like when the project is end then it should be converted into a Fixed asset?
Pranav…
Hi Pranav,
I’ve already click the finished in project stage, but nothing happen in my fixed asset number.
Is there any set up like purchasing ?
Thanks in advance
Regards
Rudy
Please show me the step, so the project can integrate to Fixed asset.
For your information, i use new FA number to registered in project.
Thanks in advance
Regards
Rudy
Hi Buddy,
As per my knowledge, I can say that, we can able to attach the fixed asset number only to the Project Types (Internal, Investment or Cost). Edit any your Projects that project types should/must be (Internal, Investment or Cost) and then select a fixed asset number under setup tab in projects. So that your current fixed assets can attached to your Project Module.
To view that attachment, follow below steps:
- From the
Fixed assets form, select the fixed asset you want.
- Expand the
Associated Projects FactBox.
- Click a project within the list to open the
Projects form, and then the projects associated with the fixed asset will be displayed.
Hope it will helps your query.
Zahir
